< Forum HYUNDAI IX et Cie depuis 2009 :: Vidange boîte - en anglais
PostPosted: Mon 6 Aug 2018 - 13:34    Post subject: Vidange boîte - en anglais Reply with quote
Service Adjustment Procedure
Oil level Check
A check of ATF level is not normally required during scheduled services. If an oil leak is found, perform the oil level check procedure after replairs are completed.
When checking the oil level, be careful not to enter dust, foreign matters, etc. from fill hole.
1.Remove the ATF Injection hole(eyebolt) (A).
Eyebolt tightening torque:
2.9 ~ 4.9 N.m (0.3 ~ 0.5 kgf.m, 2.2 ~ 3.6 lb-ft)
Always replace the O-Ring(A) of the eyebolt use new one whenever loosening eyebolt.
2.Add ATF SP-IV 700cc to the ATF injection hole.
3.Start the engine. (Don’t step on brake and accelerator simultaneously.
4.Confirm that the temperature of the A/T oil temperature sensor is 50~60°C(122~140°F) with the GDS.
5.Shift the select lever slowly from “P” to “D”, then “D” to “P” and repeat one more at idle.
Stop in each gear position for 3 seconds.
6.Lift the vehicle, then remove the oil level plug (A) from the valve body cover.
At this time, the vehicle must be a horizontal state.
7.If the oil flows out of the overflow plug in thin steady stream, the oil level is correct.
Then finish the procedure and tighten the oil plug.
Oil level check (excess or shortage) method
Excess: Drain quantity exceed 900cc for tow minutes.{50~60°C(122~140°F)}
Shortage: No drain.
If there is no damage at the automatic transaxle and the oil cooler, the oil cooler hose, transaxle case, valve body tightening state are normal, ATF must drop out after performing above 1 to 7 procedures. After performing above 1 to 7 procedures, if the oil doesn’t drop out, inspect the automatic transaxle assembly for oil leaks.
Replace the gasket before reinstalling the oil level plug.
Oil level plug tightening torque:
Tightening up stopper
8.Lower the vehicle with the lift and then tighten the eyebolt.
Replacement
ATF of 6 speed automatic transaxle doesn’t be replaced. But, if the vehicle is severe use or business use, replace ATF every 60,000 miles for severe usage.
Severe usage is defined as
Driving in rough road (Bumpy, Gravel, Snowy, Unpaved road, etc.)
Driving in mountain road, ascent/descent
Repetition of short distance driving
More than 50% operation in heavy city traffic during hot weather above 32°C(89.6°F) .
Police, Taxi, Commercial type operation or trailer towing, etc
1.Remove the drain plug (A) and reinstall the drain plug after draining ATF totally.
Drain plug tightening torque:
38.2 ~ 48.1 N.m (3.9 ~ 4.9 kgf.m, 28.2 ~ 35.4 lb-ft)
Replace the gasket before reinstalling the drain plug.
2.Fill the oil about 5 liters.
3.Check the oil level.
PostPosted: Mon 6 Aug 2018 - 13:34    Post subject: Publicité
Post new topic   Reply to topic    Forum HYUNDAI IX et Cie depuis 2009 Forum Index -> ♦ Le COIN du SANTA FE I et II jusqu'en 2010 ♦ + Relift -> Ce qu'il faut savoir sur le SANTA FE -> Santa Fe II - Répertoire -> Boîte • Transmission • 2wd - 4wd All times are GMT + 2 Hours
